getting-started:raspberry-pi-docker-install [2018/03/13 20:47]
Elco Jacobs [Go to the BrewPi web interface and connect to the Spark]
getting-started:raspberry-pi-docker-install [2019/03/16 16:51] (current)
99.93.141.76 Changed step for updating the packages on Raspian.
Line 57: Line 57:
 ==== Find the Raspberry Pi on your local network ==== ==== Find the Raspberry Pi on your local network ====
-It might not be necessary to find and remember the IP-address of your Raspberry Pi. It will register itself on the network as ''​rasbperrypi.local''​. This is provided by the package ''​avahi-daemon''​ and it is called Zeroconf.+It might not be necessary to find and remember the IP-address of your Raspberry Pi. It will register itself on the network as ''​raspberrypi.local''​. This is provided by the package ''​avahi-daemon''​ and it is called Zeroconf.
 If the .local address doesn'​t work, you can use the app Fing ([[https://​play.google.com/​store/​apps/​details?​id=com.overlook.android.fing|Android]] / [[https://​itunes.apple.com/​gb/​app/​fing-network-scanner/​id430921107|iOS]]). \\  This app can scan your local network for devices. If our Raspberry Pi successfully connected to your network, it should be on the list. Make a note of the IP address. If the .local address doesn'​t work, you can use the app Fing ([[https://​play.google.com/​store/​apps/​details?​id=com.overlook.android.fing|Android]] / [[https://​itunes.apple.com/​gb/​app/​fing-network-scanner/​id430921107|iOS]]). \\  This app can scan your local network for devices. If our Raspberry Pi successfully connected to your network, it should be on the list. Make a note of the IP address.
Line 90: Line 90:
 ==== Configure and install necessary packages ==== ==== Configure and install necessary packages ====
-Once logged in, run raspi-config to configure your locale settings and time zone:+Once logged in, run raspi-config to configure your password, ​locale settings and time zone:
 sudo raspi-config sudo raspi-config
-</​code>​
-Next, change the default password for the pi user:
-<​code>​
-passwd
 Update the packages on the system: Update the packages on the system:
-sudo apt update & sudo apt dist-upgrade+sudo apt-get update ​&& sudo apt-get dist-upgrade
 Install Docker Install Docker
-curl -sSL https://get.docker.com ​sh+curl -fsSL get.docker.com ​-o get-docker.sh && sh get-docker.sh
Line 127: Line 122:
 The command to deploy portainer is: The command to deploy portainer is:
 +docker pull portainer/​portainer
 docker run -d -p 9000:9000 -v /​var/​run/​docker.sock:/​var/​run/​docker.sock --restart always --name portainer portainer/​portainer -H unix:///​var/​run/​docker.sock docker run -d -p 9000:9000 -v /​var/​run/​docker.sock:/​var/​run/​docker.sock --restart always --name portainer portainer/​portainer -H unix:///​var/​run/​docker.sock
Line 162: Line 158:
-docker run -d --name brewpi -p 80:80 -p 81:81 -v ~/​brewpi-data:/​data -v /​etc/​timezone:/​etc/​timezone -v /​etc/​localtime:/​etc/​localtime --restart always brewpi/​brewpi-raspbian+docker pull brewpi/​brewpi-raspbian
 +docker run -d --name brewpi ​--privileged ​-p 80:80 -p 81:81 -v ~/​brewpi-data:/​data -v /​etc/​timezone:/​etc/​timezone -v /​etc/​localtime:/​etc/​localtime --restart always brewpi/​brewpi-raspbian
Line 170: Line 167:
 | <​code>​-d</​code> ​                                                              | After starting the container, run it as daemon in the background. ​                                                         | | <​code>​-d</​code> ​                                                              | After starting the container, run it as daemon in the background. ​                                                         |
 | <​code>​--name brewpi</​code> ​                                                   | Name the new container brewpi, modify this you are running multiple brewpi containers. ​                                    | | <​code>​--name brewpi</​code> ​                                                   | Name the new container brewpi, modify this you are running multiple brewpi containers. ​                                    |
 +| <​code>​--privileged</​code> ​                                                    | Run with elevated permissions to access serial ports that are present when the container starts. ​                         |
 | <​code>​-p 80:​80</​code> ​                                                        | Map port 80 of the container to port 80 of the host. <br> If port 80 is in use, use a different port, for example 8000:80. | | <​code>​-p 80:​80</​code> ​                                                        | Map port 80 of the container to port 80 of the host. <br> If port 80 is in use, use a different port, for example 8000:80. |
 | <​code>​-p 81:​81</​code> ​                                                        | Map port 81 of the container to port 81 of the host.        | | <​code>​-p 81:​81</​code> ​                                                        | Map port 81 of the container to port 81 of the host.        |
Line 178: Line 176:
-=== Connecting ​the Spark via USB ===+Please note that you need to have the BrewPi ​Spark connected ​via USB when the container starts for it to be available to the container.
 +In the web interface, you can select the serial number (for USB) or enter the IP address of the Spark to connect.
-If you want to connect to the BrewPi Spark over USB, you need to give the container access to hardware devices. ​The easiest way to do this is to pass the '--privileged' ​flag.+=== Change ​the password for port 81 ===
 +The default login details are username ​''​brewer''​ and password ''​brewpi''​.
 +To change the password, you can run:
 +sudo apt install apache2-utils
 +sudo htpasswd ​-bc ~/​brewpi-data/​settings/​brewpi.htpasswd username password
 +Replace ''​username''​ and ''​password'​' ​with your desired user name and password.
 +If you run the command inside your container instead of on the host, the command should be:
-docker run -d --name brewpi -p 80:80 -p 81:81 --privileged -v ~/brewpi-data:/data -v /etc/​timezone:/​etc/​timezone -v /​etc/​localtime:/​etc/​localtime --restart always ​brewpi/​brewpi-raspbian+sudo htpasswd ​-bc /data/settings/brewpi.htpasswd username password
-Please note that you need to have the BrewPi Spark connected via USB when the container ​starts ​for it to be available ​to the container.+=== Troubleshooting ===
 +If you get an error about a conflict with an existing container (see below), you can remove ​the old container ​or use another name for the new one.
 +docker: Error response from daemon: Conflict. The container name “/​brewpi” is already in use by container “e863…”. You have to remove (or rename) that container ​to be able to reuse that name.
 +See ‘docker run --help’.
 +To remove the existing container named '​brewpi',​ run:
 +docker stop brewpi
 +docker rm brewpi
-=== Connecting ​the BrewPi Spark via WiFi === +To view all containers, run the command below or use portainer.
- +<​code>​
-If you want to connect to the BrewPi Spark via WiFi, no extra docker ​parameters are needed. +docker ​ps -a
 ==== Go to the BrewPi web interface and connect to the Spark ==== ==== Go to the BrewPi web interface and connect to the Spark ====
