getting-started:raspberry-pi-docker-install [2018/05/02 22:46]
Elco Jacobs
getting-started:raspberry-pi-docker-install [2019/03/16 16:51] (current)
99.93.141.76 Changed step for updating the packages on Raspian.
Line 57: Line 57:
 ==== Find the Raspberry Pi on your local network ==== ==== Find the Raspberry Pi on your local network ====
-It might not be necessary to find and remember the IP-address of your Raspberry Pi. It will register itself on the network as ''​rasbperrypi.local''​. This is provided by the package ''​avahi-daemon''​ and it is called Zeroconf.+It might not be necessary to find and remember the IP-address of your Raspberry Pi. It will register itself on the network as ''​raspberrypi.local''​. This is provided by the package ''​avahi-daemon''​ and it is called Zeroconf.
 If the .local address doesn'​t work, you can use the app Fing ([[https://​play.google.com/​store/​apps/​details?​id=com.overlook.android.fing|Android]] / [[https://​itunes.apple.com/​gb/​app/​fing-network-scanner/​id430921107|iOS]]). \\  This app can scan your local network for devices. If our Raspberry Pi successfully connected to your network, it should be on the list. Make a note of the IP address. If the .local address doesn'​t work, you can use the app Fing ([[https://​play.google.com/​store/​apps/​details?​id=com.overlook.android.fing|Android]] / [[https://​itunes.apple.com/​gb/​app/​fing-network-scanner/​id430921107|iOS]]). \\  This app can scan your local network for devices. If our Raspberry Pi successfully connected to your network, it should be on the list. Make a note of the IP address.
Line 97: Line 97:
 Update the packages on the system: Update the packages on the system:
-sudo apt update & sudo apt dist-upgrade+sudo apt-get update ​&& sudo apt-get dist-upgrade
 Install Docker Install Docker
-curl -sSL https://get.docker.com ​sh+curl -fsSL get.docker.com ​-o get-docker.sh && sh get-docker.sh
